Re: no reverse evinrude 140 hp 1980
Welcome Chris! You'll find many other Aussies on the site.....please feel at home.<br /><br />First thing to do....disconnect the shift cable from the engine and shift manually at the engine.<br /><br />If it goes into forward and reverse OK, problem is in either the cables or the control. <br /><br />Is the shift cable the right length? After disconnecting the cable, move the control handle from forwards to reverse and watch the casing guide at the end of the cable. It should move back and forth freely. If it doesn't, cable may need replaced.<br /><br />If the engine will not shift into reverse, the shift rod may be out of adjustment. The shift lever at the engine, should be near verticle when the engine is in neutral. If it's way forward or to the rear, the shift rod is most likely out of adjustment.<br /><br />Has there been any work done on the lower unit which would require that it be dropped from the engine?<br /><br />Now, if it the porblem points to the control box, get a service manual before you dig in.
