  #1
Old December 11th, 2001, 06:17 AM
Duck Hunter Duck Hunter is offline
Default 9.9 Mariner Water pump
I recently sucked something up into my pump and its not pumping water, How do i get at the pump
  #2
Old December 11th, 2001, 06:43 AM
EatMoreFish EatMoreFish is offline
Default Re: 9.9 Mariner Water pump
http://www.mercurymarine.com/ have a SS number or the motor and do a search for parts on the foot like the water pump. It will show you a nice exploded pic of the foot so you can find the right part
  #3
Old December 11th, 2001, 09:22 AM
nickster nickster is offline
Duck Hunter! First thing you need is a manual. Manuals give you all of the instructions that you will need to replace and to get your motor pumping water again. Once you purchase a manual it is really easy to replace the water pump yourself it is all in there. Then if you need the manual yourself for future reference to do other service you have it. GOOD LUCK!Nick
  #4
Old December 11th, 2001, 02:31 PM
Case Case is offline
Sir, the advice from the gentlemen above is sound. Before you do anything else, get a manual for your motor (got mine from a dealer, cheaper than on the internet). Some very important points that may not be in the manual: Once satisfied that the water pump needs replacement, verify that the impeller is whole upon dissassembly. If it is not, you need to find the missing pieces; when preparing to install the new pump, lay out ALL of the pieces and dry fit them before you start the repair/replacement process. Make sure you have what you need (including gasket sealer and anti-seeze compund). Replace everything that is in the kit - no shortcuts. When you install the new impeller on the output shaft, don't forget the wodruff key (quarter moon shaped piece of metal that attaches the impeller to the output shaft. When sliding the pump housing over the impeller, be sure to turn the housing so that the blades are bending back counter clock wise.The guys are also right in telling you that it's an easy job. Take your time, check you work and it will work fine.CaseWork is fascinating - I could watch it all day...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
water pump - mariner 60 hp bech Mercury & Mariner Outboards 0 July 19th, 2005 12:52 PM
Mariner 9.9HP 628-C Water Pump Mustang1 Mercury & Mariner Outboards 1 January 17th, 2005 12:31 AM
Mariner 9.9HP 628-C Water Pump Mustang1 Non-Repair Outboard Discussions 1 January 16th, 2005 11:37 AM
mariner water pump, help! greg baranitsky Mercury & Mariner Outboards 1 June 16th, 2003 07:39 PM
Mariner 6hp won't pump out water KERT13 Mercury & Mariner Outboards 12 December 8th, 2002 05:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
