I was getting water on my 98 v-6 L/U.Pressure and vac test showed propshaft leak. I pull carrier out,put two back to back seals,o-rings .Retested and still leaks around propshaft.Wonder if I used wrong seals on that kit or some marks and nicks I saw on the shaft are causing the leak.<br /><br />Shaft is 1 1/4 in diameter.<br />Kit P/N 5006373 Bombardier.
