Re: coughing idle, 1973 - 18hp evinrude
Sounds like you've got even cylinders then. If one were sopping wet and the other dry, it can indicate a crankcase leak, a blown fuel pump diaphram, or sometimes an ignition problem.<br />Since the cylinders are affected evenly, we can safely assume that the cause is a part common to both cylinders. Carburetor, exhaust (very unlikely), fuel supply, that sort of thing.<br /><br />The o-ring on the idle mix screw is very important as it keeps the idle fuel mixture from being contaminated with air. That area of the carb is under suction. The original o-ring is not a rubber one, since it's function is more like packing in a spigot. As a matter of fact, I've used teflon packing from the plumbing department as a 'temporary' fix. As long as when you tighten up on the packing nut the mix control is getting hard to turn, I think you're probably all-right.<br /><br />I think the "bearing" you're talking about is called a "bushing". It's just a staked threaded insert pressed into the carb body. It rarely comes out, but if your packing isn't tight it may spin and prevent movement of the needle. If you're threading the needle into something, it's present. If you can turn the needle all the way until it seats, it's functioning properly. There is normally very little movement in the needle valve, but I think that would be caused by the rubber packing. The end must be a nice sharp point.<br /><br />Pumping the primer bulb does a few things. First it effectively seals any air leaks after the bulb. So any leaks in hoses, fuel fittings, etc, won't suck air. Second it overpowers the fuel pump, so if it's weak for some reason that gets masked. If there's a tear in the fuel pump's diaphram, pumping the primer will push fuel into the crankcase making the engine run much worse or even stall. If the carburetor is flooding, it will make it a lot worse and stall the engine.<br /><br />If it does nothing, then you can be reasonably sure the fuel pump and carb float, needle & seat assy are not leaking. If you suspect a rich condition (which sure sounds like what you have) then there's a few common culprits. Other than the float/needle/seat, a very common source of troubles is the nozzle gasket. That's part #40 on the epc.brp.com website. I've made temporary ones out of thick cork gasket material but they will eventually shed particles.<br /><br />EDIT: A couple other ideas, seeing this is a basket case. You don't have the air silencer down hard over the carb's mouth like a filter do you? You can even remove it for testing, it's really not supposed to affect the mix at all. Is the choke all hooked up and working properly? Opening fully?
