i checked all fuel lines and filters ran an external tank with 32:1 fuel mix after reading the manual (duhh) it calls for 50:1. im not sure but i think it hass a vro fuel pump but there is no external oil tank, alarm,or light. after my problem first occoured i noticed there was a plug unplugged on my motor so i plugged it in i looked on the wirwing schematic and cannot locate plug. and i actually forget whick plugs it was but it was neay fuel pump area. but any how if there is no oil tank should there be somthing left unplugged and could my motor be shutting down because the fuel is to lean and the pump is sensing this and shutting it down? like i said there is no light or alarm installed or if there is i dont know where it is .the motor idles fine and works at low speed but when i get on er it stalls no misfire or nothing just dies.
