  #1
Old November 25th, 2001, 06:00 AM
DBrouwer DBrouwer is offline
Default Compression for 90 hp Mercury
What is the exceptable compression range for a 1998 90hp Mercury Outboard?Also, this engine has 3 carbs, looking from the port side I noticed at the top of each carb is an adjustment screw. Next to this screw, there is a threaded hole but without a screw. I noticed that gas will come out of this hole if the fuel bulb is pumped tightly---is this some sort of vent/overflow or is a screw missing on all of the carbs?
  #2
Old November 25th, 2001, 07:26 AM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: Compression for 90 hp Mercury
You have a stuck needle valve in the carb. This needle valve is pushed up by the float,to shut off the fuel flow when the bowl is full. The carb must be removed,dssassemble at the float,needle removed and cleaned (or replaced if bad),and the carb re-assembled. Use a carb rebuild kit,and avoid re-using any of the gaskets.The compression is not in the Clymer manual.Try calling any Merc shop for that spec, or at least look for equal compression on all cylinders. The ones I have tested allways seeed low. Some of them had as low as 70PSI, but were equal, and the engines seemed to run fine at all speeds.But a shop will have the merc factory manual, and it is listed in them.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MERCURY COMPRESSION 252SCH Mercury & Mariner Outboards 4 June 21st, 2006 08:33 PM
25 hp Mercury compression terryneal Mercury & Mariner Outboards 1 June 28th, 2003 07:35 PM
New Mercury 3.3hp compression bairwin Mercury & Mariner Outboards 2 June 27th, 2003 10:40 PM
New Mercury 3.3hp compression bairwin Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 27th, 2003 10:05 PM
83 mercury no compression one cyl. koop81 Mercury & Mariner Outboards 1 June 23rd, 2003 09:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
