pursuit2460
- Aug 24, 2004
- 174
Its a 93 Johnson 225. I have replaced the power pack, stator, rec/reg, and timmer base. All the battery cables and starter solenoid. I was having the same problem before i replaced all this item. Even after the motor starts up it seems that the quick start is not ingauged the rpms never change . I have noticed on my friend motor same year and hp that when it cranks up the rpms are around 2000 and goes dropping down as it warms up meaning his quick start is working. I need help back dont know what to look for. I am priming the bulb till it gets hard hold down the the key for 10 sec. and crank. Motor was rebuild 3 years ago and it has had about 50 hours since then. The carbs. should have been rebuilt at that time also. Any suggestions .
