Wire harness plug (external)
design413
Does anyone know where i can get a wire harness for a 1975 Evinrude 25 hp with the plug that connects the battery and the starter switch to the motor? :confused:
OBJ
Re: Wire harness plug (external)
Welcome Rude25!<br /><br />Might give TwinCity Outboard or try SeaWay Marine. Both have web sites and do a lot in used/new harder to get parts.<br /><br />The part number you are looking for is 385157.<br />This part number is for the harness that connects to the engine and leads to the battery and dash mounted key switch.<br /><br />If you need a wiring diagram, pop in at the local library and look for either Seloc or Clymer service manuals. The have wiring diagrams in the back. Get a copy if the library has a copy machine.
