mercury outboard low water pump pressure/excessive smoke and unburned oil
I have just bought a 1989 60hp mercury, it had little water stream pressure at idle so I replaced the water pump. Its still the same way and I notice alot of unburned oil and smoke coming out of the prop area exhaust. also is there suppose to be some water sputtering out of the upper exhaust holes on the back of motor exhaust ports?
