  #1
Old June 19th, 2003, 05:09 PM
dleve dleve is offline
Default Mercury 25hp lost forward and reverse
regarding a 2001 mercury 25hp outboardI was cruising near wide open throttle, minding my own business when the engine started revving very high. The engine is running great but no forward or reverse. When running and in gear increasing throttle only revs the engine - no boat locomotion. Hand turning the prop with the boat in forward or reverse gear (but not running) does not turn the engine but does turn the prop shaft. I drained the lower unit oil and it was a bit cloudy but no metal chips. Anything you gentlemen could tell me will be appreciated!
  #2
Old June 19th, 2003, 07:33 PM
dkondelik dkondelik is offline
Default Re: Mercury 25hp lost forward and reverse
evenin' yellowhusky,couple of things that you might look at.First, use a white marker to mark a line in the prop hub and on the prop itself.. Star the motor, put it in gear, then turn the motor off and look at the marks. It sounds like you may have "spun" the hub. if the hub has "spun" the marks will have moved from each other. if this is what happened, you can the the prop "re-hubbed" at a prop shop or through your local marina/boat store.if that's not the problem, pull the cowel off of the motor and try to engage the shift linkage at the motor. Confirm that the shift lever is actually activating the shift shaft. the linkage have have given up in the control box, or the cable or at the mounts at the motorLet us know what you findGood Luck
  #3
Old July 11th, 2003, 08:06 AM
Seems the drive shaft was sheared. Since there was no impacts to the engine, I am taking a wild shot that Mercury will see fit to at least replace the driveshaft gratis, ha ha good luck right? Meanwhile the summer crab season is moving on without me.Thanks for your advice.Yellowhusky
  #4
Old July 21st, 2003, 06:04 PM
The driveshaft sheared down inside the lower unit housing. ANY THOUGHTS on how to remove it? The bolt is torqued holding the drive gear in the lower unit and I can't sem to hold the broken shaft end so as to remove the bolt and free the shaft end.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25 HP mercury marine-lost reverse jaguar1 Mercury & Mariner Outboards 3 June 15th, 2009 05:07 PM
No Forward or Reverse on 95 25hp evinrude banqman1000 Johnson & Evinrude Outboards 1 May 24th, 2006 03:29 PM
Lost my forward and reverse, HELP!!!!! longisldr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 29th, 2005 07:06 PM
Lost forward / reverse simultaneously jsouthco Johnson & Evinrude Outboards 3 August 10th, 2003 02:26 PM
forward lost power ,reverse fine cjkerns Johnson & Evinrude Outboards 18 August 2nd, 2002 05:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
