  #1
Old June 20th, 2006, 02:02 PM
dmadey dmadey is offline
Default Stumped -- 1981 Evinrude 70hp stalling during acceleration
Please help if you can! I've been struggling with this stalling issue on my E70ELCIH since last season and I'm stumped. I've spent weeks reading articles on this forum and have tried the suggestions I've found ... but without success so far.Symptoms/behavior of the engine is:- Engine idles well when cold and while warming up(both in and out of gear). Once the engine is hot (e.g. after running at high speed for a while), it will stall while in gear going at low speeds. - Engine runs great at high speed (once I coax it there)- Engine stalls during acceleration 90% of time. During the stall, choking the carb doesnt help and pumping the fuel bulb does not help. - In the event the engine doesnt stall, the engine moves slowly towards higher rpms like it's trying to 'catch up" to itself. The rpms steadily rise although the throttle is stationary.I've done the following work/troubleshooting in an attempt to fix it:- Rebuilt Carbs, verified proper float positioning, replaced all parts including core plugs. Verified complete cleanliness of carbs.- Rebuilt Fuel Pump. - Replaced sparkplugs. - Verified good spark in all 3 cylinders both idling and in gear.- Verified good compression (100-110 psi while trying to key-start with no plugs) - Performed partial link and sync -- I synchronized the throttle and choke linkages. I verified the timing advance at idle was 2 degrees but I havent done the maximum spark advance measurement yet. - Verified that timing plate is moving smoothly during throttle advance. The timing plate starts moving when the throttle is at about the "11:00 position" and stops moving when it's about at "10:00 position". - Verified proper tension in throttle cables- I'm using fresh gas with 50:1 ratio gas to evinrude/johnson 2-cycle oilWhat should I try next!???!? Thanks in advance for any help !!!
  #2
Old June 20th, 2006, 02:31 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Stumped -- 1981 Evinrude 70hp stalling during acceleration
I would try this: web page
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old June 20th, 2006, 03:35 PM
OBJ's Avatar
OBJ OBJ is offline
If after resetting the WOT timing doesn't work, check and make sure the choke plates are coming fully open. Doesn't sound like fuel starvation....but to much fuel. Are you sure the float settings are correct and the floats are free to move up and down?You might pull the pulse line off the fuel pump and squeeze the primer bulb. Watch for any fuel that may come out of the pulse line connection nipple on the fuel pump. If you have fuel there while squeezing the primer, it means the diaphram is shot and allowing fuel to get into the engine through the fuel pumps pulse line.Have you checked all your fuel lines to make sure all are in good condition...ie...not hard...and are making good connections?
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #4
Old June 20th, 2006, 05:31 PM
Thanks, Rick. I'll try the WOT Timing setting procedure this wknd. My boat is moored down at the creek and I wont be able to get to it before then. Thanks to you also, OBJ. The choke plates are fully open during the stalling. I verified the float settings and movement -- this is all per the manual. I just rebuilt the fuel pump so I'm pretty confident the diaphram is good. The fuel lines are pretty old and could stand to be replaced but I'm not sure how bad lines could contribute to too much fuel. However, I should probably replace these for good measure. For what it's worth, I forgot to mention in my earlier post that I also put a new powerpack on the engine last month.
  #5
Old June 20th, 2006, 06:25 PM
OBJ's Avatar
OBJ OBJ is offline
Lose fuel lines can suck air hounddog. Won't cause too much fuel but can make the engine run ragged. Sorry I didn't clarify that.....
__________________
  #6
Old June 21st, 2006, 12:24 AM
billybones billybones is offline
Hi I am new and do not know a whole lot. But did have a buddy last year with a lot of the same problems. It ended up being that the vent to the tank was plugged. was a new boat and the mechs found it while looking at it. Was an outboard. Not sure what your engine is. I am a novice. so just sort of throwing that out..
  #7
Old June 21st, 2006, 09:36 AM
Thanks, OBJ. I'm going to replace the fuel lines on Friday, when I also do the WOT timing check. I'll let you know how it runs after that. I appreciate the feedback.Billy bones, closed/clogged tank vents have stung me I've made sure mine are clear.
  #8
Old July 1st, 2006, 01:57 PM
Frank, that's really interesting. I'll have to try that.
Yesterday, I replaced every fuel line from tank to carbs and it didnt make any appreciable difference to performance. on the bright side...
- engine idles great and starts right up when engine is cold
- runs beautifully at higher RPMs. I took a 15 mile ride around the Severn River and Chesapeake Bay and the engine was very smooth.
however, persisting problrms are that...
- engine stalls during acceleration most of the time
- when engine is hot, it stalls at low speeds (e.g. going through no-wake zones after long time running at high rpm)
- when engine is hot, it has problems starting and seems to flood very easily (this flooding problem is new)
I still havent attempted the WOT measurement -- I cant access the link that Rickdb1boat posted above. I am planning to try it one night when I can get out around dusk with a friend and it's dark enough to be able to see the timing strobe on the wheel. Honestly, though, I cant see how the WOT setting would cause these issues.
So, I'm still stumped. Frank, I'm going to try your suggestion. I'll let you know what happens.
Thanks to anyone else that can help me get her running right!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
86 evinrude 30hp stalling on acceleration dtrthesignguy Johnson & Evinrude Outboards 3 July 20th, 2005 10:48 AM
1981 Evinrude 70HP questions. imstillatwork Johnson & Evinrude Outboards 6 February 1st, 2005 04:30 PM
83 Evinrude 75HP, stalling at acceleration 71whaler Johnson & Evinrude Outboards 9 July 26th, 2004 09:13 PM
77 evinrude 70hp stalling okie2301 Johnson & Evinrude Outboards 1 January 22nd, 2004 01:21 PM
70HP Evinrude 1981 Hydrolocking kemosabe Johnson & Evinrude Outboards 3 August 8th, 2003 03:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
