Re: electric starting box
if it doesn't have a generator, the only thing in the box is a solenoid. and the pass thru for the switch wires. you could eliminate it and go with the solenoid under the cowel, or just use a watertight J-box to hold it. be sure to use a marine solenoid tho, as they are sealed where the ford ones are not
