I noticed the last couple times out that my motor started smoking excessily, runs fine, but there is a big blue cloud following me around on the water. I run always and only run amsoil for my oil.<br /><br />I also have had a couple alarms go off for a short period of time in my last couple outings, it eventually stopped, both times my oil was on the low side, but nothing extreme, both times I ended up adding oil, and the problem seemed to stop..... <br /><br />So it got me to thinking a couple things, please correct me if I am wrong.<br /><br />1. When most oil pumps start to fail the fail rich for some period of time, thus my motor is suddenly using way, way more oil, which oil use alone doesn't bother me, it's the change, that now it suddenly does. I also learned today there is a filter on the oil pump unit, that has never been cleaned or changed. <br /><br />2. The alarm I recieve I *think* was a constant beep, not intermitten, I thought that was an oil warning, but it seems I may be wrong there too (oil warning are on, off, on , off, correct?), I could actually be 2 things. One I've noticed my primer bulb is not staying firm like it is suppose to, and the constant beep I think has something to do with fuel pressure, and not oil like I thought orignally. <br /><br />3. My impellar is orginal, bought the motor new, in 2001 ( though it's a '97), the the water comes out of the motor still very good, and I don't normally run the motor for too long so I question that it could be overheating, I really don't think it is.<br /><br />Time for impellar replacement anyways. <br /><br />So my orginal thought that the oil pump was failing, I'm now questioning, I was going to have it replaced, but maybe I'll just replace the filter with a new one, and replace the alarm stuff on the oil tank, which I think is come with a new filter, though I'm not sure.<br /><br />Any thoughts or comments?<br /><br /> -Nick
