  #1
Old June 15th, 2006, 11:31 PM
makoboat20c makoboat20c is offline
Default Evinrude 225 looper. Is this normal?
I am looking at this 1992 evinrude 225 hp outboard. The engine idles fine. No excessive smoke or anything abnormal. Compression on all 6 cylinder varies between 88 psi and 93 psi. Is this normal?I also did this test on the same outboard and was not sure if the following observation was normal.After starting the outboard for a few minutes, I turned the engine off, removed the cowling, and took the engine out of gear. With my bare hands behinds some work gloves, I turned the flywheel and was able to spin the engine over (In the clockwise or counter clockwise direction) with some effort. I was surprise to be able to accomplish this with out much resistant. I am not Mr. Olympia and was not on any sort of HGH or Steroids when I did this. Is there something wrong with this outboard? Is it normal to be able to turn over the engine with such little effort by griping the flywheel and turning it.
  #2
Old June 16th, 2006, 05:22 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: Evinrude 225 looper. Is this normal?
Welcome!!Compression is good, everythings normal. Do NOT turn the flywheel counterclockwise. It could possibly flip the water pump impeller blades backwards. Not likely but possible.Also don't try to shift it into gear without the motor running or turning the prop. Shifting out of gear without it running is OK.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 120 looper 65whaler Johnson & Evinrude Outboards 12 January 9th, 2007 02:51 PM
94 Evinrude 20 hp burp/far-/hic-up at moderate throttle, is this normal? tfbrown1270 Johnson & Evinrude Outboards 3 October 18th, 2006 06:23 PM
94' Evinrude v4 Looper AJ__17@BELLSOUTH.NET Johnson & Evinrude Outboards 1 July 5th, 2006 06:01 AM
evinrude 35hp is this normal?? signfinder Johnson & Evinrude Outboards 2 May 21st, 2004 05:33 AM
Bad # 5 in 87 evinrude 200 looper arhall Johnson & Evinrude Outboards 3 July 30th, 2003 05:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
