Ok, new problem....I've had my '75 Johnson 115hp engine idle for the winter. I winterized it by filling the gas tank and adding the de-waterizier....Is there anything special that I should have to do to get it running, now? Because, I can get it to crank, but it is backfiring now. Both when in neutral and in gear. The only thing that I did over the winter is replace the spark plugs. <br /><br />I have noticed that if I put my finger on the spark plug wire while the engine is running, it will shock me, duh...but I can feel it sherper when it backfires...like a needle poking. This is probably usual, huh??<br /><br />Any solutions?
