Hi - I just got a 78 Evinrude 70 HP Model 70873C
Runs great -at higher speeds it's OK - the only issue is coming back to the dock, when I throttle it back almost to an idle (still in forward gear), it stalls (not a problem - it's close enough to drift in by then!)
It'll do the same thing in low speed in reverse - I have to goose it just a bit to keep it running.
Is there an easy way to adjust the low/idle speed on it?
Thanks for any help,
Allan
