bshellrude
- Jul 26, 2004
- 66
Gents and Ladies:<br /><br />Been a while since I've posted... but seeing as the season is nearly here for us Manitoban/Canadians, I'm starting to feel the itch again of being out on the water... of course along with this comes the un-remedied headache of last season.<br /><br />Now I've done a fair bit of searching, and have for the most part come to the conclusion that I may have 2 problems... 1) A bad power pack, and; 2) A bad rectifier.<br /><br />Engine:<br />1990 Evinrude 70HP, rebuilt two seasons ago. Approximately 70Hrs on it. VRO disconnected and pre-mixing.<br /><br />Problem Symptoms:<br />Engine runs fine for 5-10 minutes. Once warmed up, and from approximately 3/4-WOT, engine begins to buck... almost like completely loosing ALL power for split seconds. Like the fuel or spark is being cut off for split seconds and then kicking back on again. This is not a condition where the engine cuts back to a specific RPM... but feels like a complete loss of power. Further to this, add the fact that if I back off the power to 3/4 or less, while keeping the boat on plane... no problems. In addition, before this loss of power is experienced, my tach drops back to 0... when I back off the throttle, the arm on the tach begins to come back up as the throttle is reduced.<br /><br />The other thing too is, the battery still seems to have plenty of power for tilt and starting... So if the rectifier was bad one would think the battery would eventually simply die and not have the power to operate the tilt pump and/or start the engine...<br /><br /><br />Things I've done to attempt to remedy:<br />1) Replaced fuel lines<br />2) Tried pumping bulb when it happens, with no change in condition<br />3) Running on Muffs, used hair dryer on individual coils to eliminate/prove a heat/electrical expansion problem with the coils, with no luck and/or clues<br />4) Replaced water pump, which incidentally caused the engine to run MUCH MUCH cooler, and with higher water pressure, but did not cause any change in symptoms<br /><br /><br />I have not:<br />1) Checked resistance of electrical components<br />2) Replaced any electrical components (due to the $$$ involved in doing so without knowing what the problem component is)<br /><br /><br />So, given the fact that while the season is upon us, but not quite here yet... I cannot run the engine yet. Looking for suggestions as to what to do next and/or what it is based on my description above.<br /><br />Thanks SO MUCH in advance.<br /><br />Ben
