Coleman1977
- Feb 11, 2006
- 16
Ok, now that I am the new owner, I have a question. I've done the usual stuff - drained lower unit (no water/metal), dropped lower unit and inspected water pump (looks brand new/very flexible)checked plugs and very good compression too. All signs that she is in good shape.<br /><br />On this model, when I get her running and up to normal temp, how much water should I expect to see from cooling system water exit hole? My newer Merc (can I say that here?)had a steady stream from the exit hole. Will the Johnson have that or a trickle or something else?<br /><br />I HAVE to ask for comfort as I had a bad experience on a Johnson about 10 years ago where the water pump went out while I was going down the lake and by the time the engine shut off from heat she was "well done".<br /><br />Thanks for any replies!<br /><br />Coleman
