robertshadow
- Mar 4, 2006
- 6
newby here, didnt find answer to my question in any other post. I recently acquired this motor for<br />nearly nothing. Seems to run good & hydroelectric<br />shift setup seems to work in the driveway, havent<br />had it in the water yet. Lower unit fluid looks <br />good. Seems a tad low, does not runout of top hole. I gather from reading here that this thing <br />uses hydrualic pressure to transmit motion: correct??? If so, what fluid do I need use in the<br />lower unit? I would like to change it before 1st<br />use & sure dont want to put anything in it that will damage it. Thanks for any info.
