  #1
Old June 4th, 2006, 10:22 PM
Clearsky Clearsky is offline
Default Oil leak from behind prop Evinrude 60HP 1990
After about 4 weeks sitting with engine fully down I noticed a small amount of oil seeping from behind the prop. The oil is pitch black, and only a few drops have come out, nothing came out for the 1st 3 weeks of sitting with engine down. I have checked the oil in the gearcase and it was clear and was still full. I have run the engine on muffs a couple of times in the 4 weeks. Could the oil just be exhaust residue? or is it likely to be a seal behind the prop.Just one more thing, is it recommeneded to leave engine down or up when not in use for long periods? I put it down as I was thinking it would relieve from pressure from the transom and the tilt and trim, but I'm only guessing.Any advice would be great.Thanks
  #2
Old June 4th, 2006, 11:03 PM
ob ob is offline
Default Re: Oil leak from behind prop Evinrude 60HP 1990
It's just exhaust residue.No big woop.If the exhaust housing however is collecting this residue regularly,it is indicative of the engine being in need of a decarb.Might also insure that 60 hp engine is propped to turn 5500-6000 at wide open throttle as well.Overpropping causes coking of cylinders as well.Lots of slow speed trolling loads them up too.
  #3
Old June 4th, 2006, 11:13 PM
Thanks OB,I should have mentioned, I'm running a 25 to 1 fuel to oil mix at present as engine is being run in after a rebuild, I would imagine this fuel mix could add to the problem.
  #4
Old June 4th, 2006, 11:18 PM
ob ob is offline
Absolutely.Get throught the break-in and see if she clears up.Anyway,make sure that engine as propped will rap out to the rpms I mentioned above or you'll be doing another overhaul sooner than expected.
  #5
Old June 4th, 2006, 11:29 PM
Thanks again OB,Were just coming into winter here in aus, but next time I take her out I'll check that I can get the 5500-6000. I have only had the boat for a couple of months, I know I've had it up to 5000RPM but not sure if this was WOT, I think there was bit more in her, but I'll double check it.
  #6
Old June 5th, 2006, 12:07 AM
ob ob is offline
Cheers and happy boating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 60hp 1990 Failed Again and Again RonA Johnson & Evinrude Outboards 7 November 29th, 2005 11:18 PM
Prop fine-tuning 1990 Merc 60hp olyerickson Mercury & Mariner Outboards 4 October 11th, 2004 04:49 AM
1990 Evinrude 60hp NathanY Johnson & Evinrude Outboards 1 July 26th, 2004 05:28 AM
1990 60hp evinrude sandron19 Johnson & Evinrude Outboards 4 July 1st, 2003 09:48 AM
1990 60HP Evinrude mlcatlopez Johnson & Evinrude Outboards 13 December 12th, 2002 04:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
