Hi all,<br />I have a 87' 20hp Evinrude outboard that i have been tying to install a new lower unit seal and a impeller. I dropped the lower unit the lower unit and the shaft pulled out of the lower unit. I've been trying to reinstall the shaft to the lower unit gear, but its not engaging. Is there someone that know a trick to installing the shaft? I don't own a repair manuel, but it look like I'll need one.<br /><br />Also if anyone could give me a pointer on how to pull the gear housing from lower unit, so i can install new o-ring seal??<br /><br />I appreciate any info i could get from ya'll.<br />Thanks.
