Re: starter motor 1989 evi 110 screeming
Both end caps have pressed bushings. They support the armature. Check to see if the armature seems loose. Likely that the bushing clearance is loosening, and the shaft may be vibrating as the armature rotates, making the noise. Both caps are sold separately.
