  #1
Old May 28th, 2006, 01:55 PM
woojadoit woojadoit is offline
Default 1992 evinrude 70 hp Idles fine till I put it in gear in water
1992 evinrude 70 hp Idles and revs fine till I put it in gear in the water. Then it dies.I have new plugs....Help..
  #2
Old May 28th, 2006, 02:11 PM
Silvertip Silvertip is offline
Default Re: 1992 evinrude 70 hp Idles fine till I put it in gear in water
Did you by any chance adjust the carbs running the engine on muffs? If so, readjust them with the engine in the water. No back pressure on muffs. Check link&sync, then readjust idle mixture and idle speed.
  #3
Old May 29th, 2006, 08:55 AM
the machinist the machinist is offline
Check the propshaft for fishing line wound around it. It can be bad enough that the resistance is so great that the motor can not overcome it while in the slow speed required to shift.
  #4
Old May 30th, 2006, 05:11 AM
The enging spins the prop fine when we put it in gear. So fishing line isnt the problem. As for adjusting the carbs that might be the problem. We're also running bad gas from last year. weve added octaine boost and carb cleaner, we diddnt ad stabilizer last fall either.......The back pressure thing sounds like definate possibility.
  #5
Old May 30th, 2006, 08:02 AM
Quote:
Originally posted by Upinsmoke: Did you by any chance adjust the carbs running the engine on muffs? If so, readjust them with the engine in the water. No back pressure on muffs. Check link&sync, then readjust idle mixture and idle speed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
6HP Evinrude 1979 slows down at full throttle in gear, idles fine LookaSnooka Johnson & Evinrude Outboards 2 March 18th, 2005 07:22 AM
starts fine ,idles fine, bogs out full throttle. duckgun Mercury & Mariner Outboards 3 October 18th, 2004 11:03 PM
225 idles fine then rev on its own GDB Johnson & Evinrude Outboards 7 August 30th, 2004 04:10 AM
1989 Evinrude 60 hp idles fine but lacks power rjwiles Johnson & Evinrude Outboards 3 August 8th, 2003 07:02 PM
Mercury 115hp idles fine, dies when put into gear rhotec Mercury & Mariner Outboards 1 July 2nd, 2003 06:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
