Re: old 175 ran well but now will not start
Spark plugs should be Champion QL77JC4 plugs, gapped at .040.<br /><br />Compression should be 100+ psi and even on all cylinders. Is it?<br /><br />With the spark plugs removed, rig a spark tester whereas you can set a 7/16" gap (don't check the spark by using the plugs). The tester and that 7/16" gap is a must.<br /><br />At cranking speed, the spark should jump that gap with a strong blue lightning like flame.... a real SNAP! Does it?<br /><br />There's a few home made spark testers listed here at "iboats". Do a search for "spark tester" and they should show up.<br /><br />If the above two tests prove to be okay, check the carburetors for fuel. If you started with a empty tank, then added oil first, that raw oil would be pushed up the feed tube and into the carburetor float chambers when you added the gasoline. On a empty tank, add a couple gallons of gas, then the oil, then the rest of the gas.<br /><br />Let us know what you find. Be specific, don't just say that the compression and spark was okay, describe what you find fully.
