  #1
Old May 26th, 2006, 08:11 PM
riden riden is offline
Default Evinrude 90 starter trouble
I am a complete newbie.I bought a boat and am learning as I go, I bought it yesterday. I am mechanically inclined and not as dumb as this 1st post may appear.Haven't put the boat in the water yet, it is a 78 Lund custom, in good shape.Motor is a 94 Evinrude 90 V-4In the yard when I turn the key the starter spins but the shaft doesn't move and engage the flywheel.What could cause this? Is it possible that the leg must be filled with water??Any newbie sites would also be appreciated.
  #2
Old May 26th, 2006, 09:01 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: Evinrude 90 starter trouble
Welcome riden! Just keep in mind....there are NO dumb questions here.Do a couple simple things first....take some WD40 or some light lube and put several dabs around the starter bendix shaft and work the bendix up and down.Make sure the battery is fully charged and the connections from the battery to the engine are all clean and tight...including the grounds.Give the starter another try. If the bendix pops up and engages the flywheel and she cranks...should be good to go.If it seems the starter still lacks the power to get the bendix up, jump across the starter solenoids two large posts with a screw driver. If the engine starts to crank good, then likely the solenoid is in need of replacement.Give it a shot and post back and let us know what ya' find.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old May 26th, 2006, 09:49 PM
Thanks OBJI ordered a manual.I will give that a try in the AM, good advice.Edited to add: I put on charger on the battery and wow is it sucking juice. I saw the starter spinning and thought the battery have lots of junk.I am sure on the bottom end of the learning curve on these outboards.Thanks again, let you know what happens.
  #4
Old May 27th, 2006, 01:12 PM
It was the battery causing all the trouble.Thanks again
  #5
Old May 27th, 2006, 01:44 PM
DHPMARINE DHPMARINE is offline
And now you are a step up on that learning curve. Keep asking and learning.That's what this is all about.DHP
  #6
Old May 27th, 2006, 01:58 PM
OBJ's Avatar
OBJ OBJ is offline
And thanks for posting back....could help some else.....good job riden!
__________________
  #7
Old May 27th, 2006, 09:16 PM
Good chance I will be back with more questions. Not real comfortable knowing so little, I don't want to be at the bottom of this curve for long.Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starter Trouble willm22 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 8th, 2006 08:36 AM
Trouble with Starter on 84 Evinrude 115 mulv80 Johnson & Evinrude Outboards 3 March 27th, 2006 12:08 PM
Starter trouble on 1985 Evinrude 90 hp... Dave CFI Johnson & Evinrude Outboards 4 May 27th, 2003 08:49 AM
1970 Evinrude "Selectric" 60hp Starter Trouble hcrumbie Johnson & Evinrude Outboards 3 April 14th, 2003 11:08 AM
Starter Trouble kbaker7544 Mercury & Mariner Outboards 2 August 13th, 2002 11:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
