Re: Johnson 140TL79R top two cylinders not firing
Welcome Jim!<br /><br />A question or two....when you say the cylinders are not firing but have spark, does this mean that when the engine is running the spark quits or it seems that they are not getting fuel? What do the spark plugs look like after running and kind are they?<br /><br />Is this a new engine to you or did this problem just occur? If this engine is new to you, has it been setting for a long time?<br /><br />Have you taken compression readings on all cylinders yet? Would be a good place to start. Will give you an idea as to what shape the cylinders are in. And check the spark again to each cylinder. The sparks should be able to jump at least a 7/16" gap with a hot lighting like spark.<br /><br />I know....lots of questions. But knowing the above will help. A service manual would help you a lot.
