Re: 1973 Johnson
lemrac,<br />Lots of things to do to try to get your spark back.<br />BUT 60PSI is too low.I don't try to fix an outboard with less than 70PSI.And those don't always pan out.<br />Maybe pull the cylinder head off and inspect things.If all looks good,reinstall the head with a new gasket,and if compression comes up,then pursue the spark problem ?<br /><br />DHP
