This might be a weird one but my local dealer suggested I could damage a water pump on an early Evinrude (72) by running it in a 20 litre (5.5 Gallons) bucket. The bucket was deep enough to cover up to the extention housing. He said the the exhaust gas could come out of the outlet hit the bucket and be sucked back into the water inlet screen. Ten seconds is all it takes he says. Have to use a BIG drum or it will be toast.<br /><br />By the way the engine is only in neutral, you sure would empty that bucket real fast if you clicked it into gear!<br /><br />What do you think?? Has anyone heard of this??
