Hi guys Im having a problem with 1999 50hp johnson electric start motor. This motor will start fine cold and run fine until i turn it off. When i go to start the motor again It will not start it turns over but will not fire. This does not happen all the time id say about 30%. I thought I might have had a carb problem so I cleaned both carbs and also installed two new carb kits. Needless to say i still have the same problem. Thanks for any help Bill
