Re: Johnson 55hp Won't Start in Water
welcome to iboats!<br /><br />Henry, first let's get an idea of where we stand.<br /><br />1)compression check--good being 100+, and close together <br /><br />2)spark check--thick and blue? needs to jump 7/16"gap and be snappy<br /><br />3)carb and fuel system check--when was last overhaul?<br /><br />an unhealthy engine will often run fine on the muffs, but nothing when in the water due to backpressure. <br /><br />could be weak spark, no spark on a cylinder, could be lower compression.
