Evinrude/Jonshon compatability
rcabunac
Hello,<br /><br />Can anyone tell me what parts if any from a 1971 50HP Johnson Mod#50ESL71S are interchangable to a 1973 50HP Evinrude (Lasrk) Mod# 50372R? <br /><br />Want to use parts from the Johnson for the Evinrude.<br /><br />Thanks
MCM
Re: Evinrude/Jonshon compatability
Welcome to iboats,<br /><br />That covers alot of territory, maybe if you could be more specific as to which parts it might help. <br /><br />You could always go to the BRP site http://epc.brp.com/default.aspx?brands=ej&lang=E <br />, you can cross reference between the two motors using the diagrams and parts lists
rcabunac
How about the power head, or any components of the lower unit? Carbs?
rcabunac
Good link, I see at least a float assembly is the same, some parts are some parts are not. Great :)
MCM
Once you locate specific p/n's you can use the advanced feature (located where it says normal) and type in the p/n and it will show all models where that part was used.
