I am looking for a wiring diagram for a 70's model Evinrude 60 HP keyswitch. The replacement switch has the standard A, B, S, M, C, M terminals. Wires are black, black/yellow, red, purple/white, double purple, yellow.
Hi Pat and welcome to iboats!The black wire will go to one of the "M"'s.The black/yellow stripe wire will go to the other "M". One of the "M" terminals is an "upright" terminal...or should be...this is where the Black/yellow usually goes. If all the terminals are the same, it doesn't make any difference what "M" terminals are used.Purple/white stripe wire goes to the "C"...choke.Yellow wire will go to the "S"...start.Red wire goes to the "B"...battery.Double purple goes to the "A"...accessory.Hope this helps.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
