28 hp evinrude shaft length
jerrymarkey
I have a 1987 Evinrude long shaft motor that I want to change to short shaft. Can I just remove the section above the propellor or is there more to it than that. Will I need additional parts or will removing parts do the trick? jerrymarkey@comcast.net
JB
Re: 28 hp evinrude shaft length
You will need a different driveshaft, water pipe and shift rod, at least, Jerry.<br /><br />Check with tcoutboard.com about swapping for used parts.<br /><br />Good luck. :)
