EdwardNigma
- Dec 26, 2005
- 30
I'm not quite certain that this is the best forum for this question, but I didn't see a more obvious choice so here goes.<br /><br /> I'm in the process of buying a used boat with a 1978 175hp Johnson. I'm looking for info on this motor such as whether or not it's a cross flow or looper, recommended spark plugs, charging system output etc etc. A condition of me buying it is a test drive this spring once the rivers are wet again, what should I look for that would indicate a motor I want to avoid? The model number on the mounting bracket is 175TL78C. I've also got some questions about the prop that the current owner is using, but I'll post those over in the prop forum. <br /><br /> Thanks for any sage advice you gentlemen can provide.
