When in the water my motor will not pick up the RPM's, dogs down really bad (almost like it's muffled, I don't think it's the water pump because the water comes out real good through the hose. When I put the flush kit on it at home it will top out the RPM's but backfires through the exhaust within the prop. I have replaced both head gasket, thermostats etc. I also checked the compression and all 4 cylinders are between 105-115 psi. Like I said it seems like the pump/impeller is working both in and out of the water?
Any help is greatly appreciated
Thanks
