I'm having trouble with my engine battery draining after 4-5 days. I've isolated each lead and determined that the current draw is coming from the engine. I keep my boat in the water and had some excessive corrosion on the anodes. I had the voltage regulator replaced, but the drain is still happening. The corrosion has stopped though. What could be the problem?<br /><br />Thanks.
