Fred Weston
- Nov 13, 2005
- 6
I am trying to drop the lower unit on my 1977 Johnson 85hp outboard. I screwed up and removed the lower unit without disconnecting the shift rod first because I did not have a repair manual when I started. Now the lower unit is partially disconnected and I believe the shift rod is the only thing still keeping it from coming off.<br /><br />I have supported the lower unit with a floor jack and removed the "carburetor / intake" (please excuse me if this is not the correct name) located at the bottom of the crankcase right above the top of the shift rod. There seems to be some sort of retaining pin installed through the top of the shift rod and I need to know how to remove it. There does not seem to be much clearance on any side, so getting a punch in there seems unlikely. To get an idea of what I am talking about, check out this picture: http://files.fredwick.com/files/2193192400851570.jpg <br /><br />Any help is appreciated!
