Re: Run Dry or Not!
Regarding the Alcohol extenders; in NJ the fuel does not have alcohol. In NY it does, but not enough to exceed the specs by OMC.<br /><br />Walker is right, since 1995 the Environmental Protection Agency (EPA), through the Clean Air Act, mandates that cleaners be added to all fuel. None the less, according to my Exxon Engineer source, Premium still has more cleaners than regular. You are not just paying for octane. <br /><br /> <br />And from our friends at Shell:<br /><br />"Today we estimate that 60% of fuels sold in the US are at or near the minimum level of detergency allowed by law.
However years of vehicle testing by Shell has shown that the EPA minimum level of detergency is not sufficient to prevent deposit build-up in some cars. We have measured significant deposit build-up in certain vehicles in as little as 5000 miles. Testing has further shown that some of those vehicles can experience cold start drivability problems as a result.<br /><br /> The image shows Intake Valves after a 5,000 mile Shell test comparing Shell V-Power to a discount brand premium gasoline.<br /><br />
<br /><br />(Note: this is regular cheapo brand vs Shell Premium. Quite the difference! What cheapo brand do you run?) <br /> <br />
Shell regular and mid-grade gasolines contain more than twice the amount of detergents required by the EPA. This level of protection helps prevent the future build-up of carbon deposits on your vehicles intake valves or fuel injectors. However, if you use discount gasolines, you may already have intake valve or fuel injector deposits, which may need to be cleaned up. That is where Shell V-Power® comes in." <br /><br />Regarding their premium brand fuel:<br /><br />"
Shell V-Power® premium gasoline can clean up deposits on intake valves and fuel injectors left behind by low detergent gasolines. Thats because it contains more than five times the amount of cleaning agents required by government standards."<br /><br />So, yes, my dear Scarlett, Premium fuel does have more cleaners than regular or mid grade. Depending on manufacturer, up to 5 times as much.
<br /><br />Also the lube oil added to the burn mix creates more residue to build up. Cheap fuel with oil is not my first choice to run in my 2 cycle!!! Clean burning TCW3 does not mean Zero residue, it just means less buildup than burning straight 30 weight.<br /><br />I know that some of you guys burn hundreds of gallons a year. The cost of premium adds up. But for boaters like myself who burn about 100 gallons a year, the cost of premium over regular is only an additional $20 a season to get the higher level of protection. Compare that to fuel additives at the parts store to treat 100 gallons will cost more than the price of buying the premium at the pump. Today my local station has regular at 2.09 and premium at 2.29.<br /><br />bold accents added by your truely.<br /> <br />BTW, why is this picture of Peter Jennings on the Exxon Mobil web page?<br /><br />
<br /><br />Alright, so it's not really him, but the resemblance is striking.
