  #1
Old May 14th, 2006, 04:06 PM
fab fab is offline
Default 60hp 1987 evinrude stalls at low rpm & when shifting in gear
I just purchased a 1987 60hp Evinrude and it was sitting for a few years. Brought it to a marine mechanic to tune it up and brought out on the water today for the first time. It seems to run great at high speeds but stalls when it runs at low rpm or when shifting into gear from neutral. I had mixed the gas just by eye didnÂ’t really measure exact quantity could the fuel be to rich.
  #2
Old May 14th, 2006, 05:10 PM
h_lankford h_lankford is offline
Default Re: 60hp 1987 evinrude stalls at low rpm & when shifting in gear
without asking any diagnostic questions as to why this is happening, why not just simply increase idle speed adjustment screw? And....your engine's longevity depends on correct gas/oil mix.
  #3
Old May 4th, 2008, 09:43 AM
dmarti06 dmarti06 is offline
Hi
I'm having the same problem with my 1987 3cylinder 60hp evinrude.
Let me know what if anything you found to correcting this issue. I allready rebuilt all carbs thinking this would solve it(it helped) since now goes on reverse and forward but when I kick it to go and take off, it still starves for gas and I need to give it gas with solenoid or it will shut off. After taking off it will run just fine. This is driving me nuts.
  #4
Old May 5th, 2008, 12:31 AM
breeder44's Avatar
breeder44 breeder44 is offline
Same problem here with 1981 50 HP Merc. I haven't tried adjusting the idle screw but I will try that.
  #5
Old May 19th, 2008, 04:41 PM
smarvelle smarvelle is offline
I was wondering if adjusting the idle screw worked? Thanks
  #6
Old May 19th, 2008, 06:01 PM
wlbolerdo wlbolerdo is offline
I have a '92 70hp evinrude that had the same problem, stalled putting in gear! WOT ran great. A friend of mine adjusted the carbs and then adjusted the linkage(link and sinq). No problems after that. Adjusting the idle rpm has to be done under a load, prop has to be in the water in gear. It cannot be done properly with the ears and the hose in the driveway.
Also my understanding is that idle adjustment is done with engine timing- in other words, a timing light. Well good luck and I hope this helps, it helped me.
Wayne
  #7
Old May 19th, 2008, 06:47 PM
athertop athertop is offline
I had exactly the same problem on my '82 Evinrude 60 2-cyl, and it turned out to be loss of compression on one cylinder - I'd recommend doing a compression test.
Hope you have better luck than me! Cheers, Paul
  #8
Old May 23rd, 2008, 01:12 PM
jfmac jfmac is offline
Same problem on my '83 Evinrude 50. I did all the things I could find to be recommended in this list (Seafoam treatment, link and sync, clean carbs, check and clean out orifices, fuel lines, etc) and it smoothed out the engine running but did not improve the original problem. Just the other day I found that one vacuum hose running to the mid-speed orifice of one carb had a crack in it just past where it fit on the carb fitting. I cut that off and remounted the tube. Voila, new engine. Runs perfectly and I can floor the throttle from its lowest in gear speed to WOT without it dying (used to have to keep punching the choke and inching up the throttle until it caught at the higher rpm). So, add to the list to check any vacuum lines to all the carbs. Mine run from the back of the air intake housing to some splitters and then to the various carb fittings.
Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 125 Force Dies when shifting into gear FMG Force & Chrysler Outboards 12 July 1st, 2006 01:20 AM
1992 60hp 3 cylinder stalls going into gear koolerb Johnson & Evinrude Outboards 1 June 29th, 2006 09:09 PM
1983 60HP Evinrude stalls when put in gear when warm athertop Johnson & Evinrude Outboards 2 September 4th, 2004 01:11 PM
'87 Mariner 60hp stalls into and out of gear. RAB1397 Mercury & Mariner Outboards 5 July 12th, 2002 06:16 PM
johnson 60hp stalls when put in gear and low idle for a while mookieo2 Johnson & Evinrude Outboards 2 June 13th, 2002 07:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
