  #1
Old May 14th, 2006, 09:26 AM
igglesjo igglesjo is offline
Default 1995 Evinrude 70HP Power Loss
I have a 1995 70 Hp motor. I have never had a problem with the motor until very recently. the motor starts immediately, idles good and runs at low speed well. I moved the throttle to full power yesterday, and the boat RPM went up somewhat but not as high as it should have, and the boat was not moving fast at all. I took the motor out of gear, and revved it up in Neutral and the motor seemed to rev up just fine. The water flow is fine out of the port. When I put the boat up for the winter last year, I had the water pump changed and the lower unit serviced. The first time out with the boat everything seemed fine. two weeks later, I can not get full power. anyone know what this sounds like?
  #2
Old May 14th, 2006, 10:23 AM
angus63's Avatar
angus63 angus63 is offline
Default Re: 1995 Evinrude 70HP Power Loss
Welcome!!!!Revving in neutral tells nothing about the health of your motor. That being said.....1) Fuel-- Try a fresh tank if fuel is over a month old. Check for leaks or fuel bulb collapsing.2) Spark--- Verify plugs are firing every stroke with a bright spark 3) Compression --- appx 100 psi and within 10% of each other.I would guess fuel condition first. If not, check the others and post your results.Good luck
__________________
USMMA Kings Point
  #3
Old May 14th, 2006, 12:22 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Might try running on a separate 6 gallon tank with fresh fuel/oil mix with new fittings and bulb and see if that does it. Sounds like you may have picked up some water in the fuel...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old May 14th, 2006, 12:40 PM
DJ DJ is offline
You're not running on all three. Either spark or a fueled carburetor.
  #5
Old May 14th, 2006, 04:19 PM
jtexas's Avatar
jtexas jtexas is offline
DJ means "fouled carb"
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 70hp power loss evinrude clayvogt6358 Johnson & Evinrude Outboards 2 April 24th, 2006 06:34 AM
1977 70hp power loss evinrude clayvogt6358 Other Outboard Brands 1 April 24th, 2006 06:17 AM
93 70hp force power and rpm loss gsxr11 Force & Chrysler Outboards 16 March 26th, 2004 01:34 PM
1995 Johnson 150 power loss PeteS Johnson & Evinrude Outboards 4 May 2nd, 2003 07:41 PM
1995 Evinrude 150HP Ocean Pro loss of power popov Johnson & Evinrude Outboards 5 July 16th, 2002 12:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
