Re: 1986 50 hp Evinrude Shift Linkage removal
Hey Bob....You will need to remove the bolt completely, the bolt goes though the shift rod in order to hold it in, so once you remove it, the shift rod will slide out when you remove the lower unit. Be sure not to move(twist) the shift rod once you get the lower unit down, twisting it will adjust the height and cause you problems on re-assembly.
