motors have run just fine on 50:1 premix for decades. you will sleep well at night doing it, never worrying about the VRO failing again.( twice in my case). Others will chime in that it is a good system, that is, if the oil tank doesn't sludge up, if the hoses don't suck air, if, if, if if, if. I just said chuck it. easy enough to premix. I just left the unit in place to pump gas(premix) but disconnected the oil line and the oil warning wires.
PS you are very lean when running 5000 in neutral/no load. it's not good because lean means lean gas AND lean oil. Harvey
