Just purchased a 1964 Evinrude Lightwin 3hp outboard folding motor off of Ebay. model # 3602E<br />serial E02715. It has not been run for 6 years. Took off tank, cleaned carb, heads, spark-plugs, drained and replaced lower unit oil. 2 Questions, 1. how do I service the middle unit (the portion of the motor that holds the shaft)? There is a grease fitting in the middle and a little screw at the top. 2. Since this is a folding motor, there is a roll pin (looks like a shear pin) that engages the drive shaft of the middle unit with the lower unit when the two halves are joined together. Is this the shear pin? Or is it located at the prop? Thanks for the help. Jim <br /><br />model # 3602E<br />serial E02715
