Re: 63 Evinrude 40 hp submerged
Ok, first you've got to make sure you have all the water out of the engine. Remove the spark plugs, and turn the engine so one piston is at top dead centre. Lay the engine on it's port side (shift lever sticking up if it's got one / if not throttle side sticking down) and rotate it on to it's back so the spark plugs are sticking up, then just a bit further. Check to see if any water runs out. Rotate the flywheel 180° and repeat. This will drain the crankcase chambers.<br />If salt water comes out, pour some isopropyl (rubbing) alcohol down the cylinders, rotate the engine a few times, and then pour it out as above. The alcohol will absorb the water.<br />When you're done, drop a couple tablespoons of TC-W3 down each spark plug hole with the engine on it's front, wait 10 minutes, and then turn the engine a few times to distribute the oil. <br /><br />If you have weak spark, the most likely cause is that the points are contaminated, not the condensors or the leads. In fact, I have re-used condensors that sat a week in salt water. If the coils are old and cracked, that is the next most likely source of trouble. The spark should be able to jump at least 1/4", if it's only a spark plug's gap it won't ignite the fuel/air mix under compression.<br /><br />Have you got a harmonic balancer puller?
