78 johnson 140 gear case compatibility
spragusa
What other year and size lower units will bolt up without having to change out any parts ?
Marc J.
Re: 78 johnson 140 gear case compatibility
From what I've read here, you're in luck. Any V4 gearcase from 1978 to 1995 will work. Prior to that they changed every couple of years. Just use 1978 shift rod height specs.
