Re: 96 OMC/Johnson Won't Tilt
First, an overview of the system...<br /><br />You should hav a two wire trim motor (blue and green). The motor runs with 12 volts applied, and runs in reverse when the 12v is reversed on the leads from the motor. The trim relays at rest are both sending ground to the motor. When energized, the 'up' relay sends 12v+ to the blue wire (blue skies), or 'down' sends 12v+ to the green wire (green grass).<br /><br />First, make sure the ground and 12V supply are good to the trim relay assembly, and that the two wire plug in to the trim motor (just under the relay assembly) is clean and tight. <br /><br />Unplug the two wire connector to the trim motor (blue and green wires, heavier guage than the other wires) and apply 12V to blue and ground to green on the motor side of the connection. Motor should run and tilt angle should increase. If trim motor does not run, it is bad. Reverse the 12V and ground, trim motor should run and tilt angle should decrease. If trim motor does not run, it is bad.<br /><br />Check the relays with a test light. To check the ground side of the relays, attach the test light lead to a good 12V source, and probe each wire on the relay side of the same two wire trim motor connection. Test light should light on each wire. Connect the test light lead to a good ground on the motor, and probe each wire again. The blue wire should light the test light when the up trim button is pushed and the green should light it when down trim is pushed. If any portion of this test fails to light the test light, you have a bad trim relay. I recommend replacing both relays if either is bad.<br /><br />NOTE: If all tests pass and your trim motor still doesn't run, the relays still could be bad. The relay(s) may not be making a good enough connection to carry the heavier current needed to operate the trim motor.
