jtexas
- Oct 13, 2003
- 8,646
it's a 1979 70hp, model 70973, the tilt/trim is not covered in the manual but is an "OMC Power Tilt Kit", found the diagram on the BRP diagram site, see below. No trim, just tilt.<br /><br />It's getting weak, starting to complain a bit, & won't hold the motor up for low speed shallow running as good as it used to.<br /><br />It's not clear to me how to add fluid or even check the level. I don't mind hacking into it on my own, but if anybody remembers ever working on one a these & has some advice, I sure would appreciate it.<br /><br />THANKS!!<br /><br />
