Just put a '95 Johnson 50 hp back together for piston/block issues and find no spark upon cranking. My experience has been with '80's motors without the relays on the ECU bracket. I have not yet tried for spark with the red harness connector unplugged but have checked with ohmmeter for correct operation of ignition switch/kill switch at the connector junction. I would like to know what the function of the relays located on the ECU bracket are. Just wondering if they are somehow tied to a low oil sensor etc. Word was that someone had disconnected the buzzer at the throttle/gearshift control and this had been reconnected just prior to me pulling the powerhead. Thanks for any help you might be able to give.
