  #1
Old April 25th, 2006, 11:39 AM
sperry sperry is offline
Default '88 evinrude starter prob
I have a 1988, 70 hp VRO. My father took the boat out fishing and the starter did not engage the starter gear to the flywheel. It just stayed in the "down" position and spun. He manually screwed the shaft up until it engaged the flywheel and rotated the fly wheel till enough pressure existed to keep the starter shaft from retracting. Then he started the engine. When he got the boat home, he sprayed silicone lube on the shaft. We tried cranking the engine at various times for 2 weeks--never a problem. He took the boat out again and started and stopped the engine 5-10 times, but the same problem finally repeated. Is there an easy/ cheaper solution to this problem than buying a new starter for $220!
  #2
Old April 25th, 2006, 12:04 PM
KYHunter2 KYHunter2 is offline
Default Re: '88 evinrude starter prob
Make sure you have a very good battery. All cables/ wires, and connections in good shape. Or that the charging system ,is working correctly. Kinda sounds like the battery is getting drawn down , and isnt sufficient, to operate starter. When it messes up again , connect a known good battery ,and see if it engages. If it does , then its either battery or charging system. Thats my guess anyway. Good Luck, KYhunter Oh, I forgot, DUH, you can take starter to auto parts, and have it tested. Still check the batt. and charging system.
  #3
Old April 25th, 2006, 03:38 PM
Silvertip Silvertip is offline
The grooves in the starter shaft and the ridges on the bendix must be kept clean. So the bendix can rise and fall freely. If these are gunked up with grease you will experience the problem you are having. You don't need a new starter. If it needs repair your local auto electric shop (aka starter/generator/alternator shop) can do the job very reasonably.
  #4
Old April 25th, 2006, 05:52 PM
JB's Avatar
JB JB is offline
Common problem on the 70s.Take the ground cable off where it bolts to the block/bypass cover. Clean both connections and reinstall.Or you can go here: http://forums.iboats.com/cgi-bin/ubb...;f=36;t=000001 and troubleshoot the starter circuit.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50HP EFI Starter prob. Gone Mercury & Mariner Outboards 4 August 16th, 2006 08:03 AM
75" 50hp Johnson Starter Prob busta151 Johnson & Evinrude Outboards 2 December 8th, 2005 11:00 AM
1977 Johnson 140 starter prob HOUSTON1 Johnson & Evinrude Outboards 3 October 27th, 2005 06:11 PM
1978 1150 starter bendix prob sundog Mercury & Mariner Outboards 1 November 14th, 2003 07:12 AM
starter relay prob. johnson 175 Daniel Beckman Johnson & Evinrude Outboards 3 July 18th, 2002 02:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
