Year and more:
Evinrude Model 33552 (SkiTwin)
Year: 1965
HP: 33
WOT RPMS: 4500
Displacement: 40.5 cu.in. = 663.7 ccm
Cylinders: 2
Weight: 127 - 140 lbs. = 57.6 - 63.5 Kg
Gear Ratio: 12:21
Spark plug: Champion J4C (was J4J) gapped at .030"
Fuel/oil mix: 50:1 87 octane gas to TCW-3 rated outboard oil.
(The 33hp engine has no thermostat, and water should gush out the large hole at the back when you start it)
From the Old OMC Site
